Second 40
On this episode of what do I need to fab, I got the battery box modified and mounted.
Got throttle hooked up by reusing some brackets and with the new throttle cable kit . Also hooked up the vacuum pump hooked up to the brake booster.
I'm at a point where I need to order some parts so I shifted gears and started working on the interior. I assembled my tubing notcher and started assembling the kit that I bought from Metal Tech. The kit is very nice with one end of pipes already notched where there are pipes that require two notched ends.
Got most of it tacked in and position the front posts so I can roll up/down the windows.
Looking good... Want to rent out that notcher sometime ;)
Laces out...bold move!
Sure. If you want to put the cage in just bring your cruiser over we'll have a build fest.
I have had a metal tech cage in my garage for 5 years :lol:
Well I can't wait till this weekend to see if this works out.
Got the first phase of the cage burned in and painted.
More cage work today. Got the front passenger side frame tie-in done and got the front spreaders cut and ready to burn in.
Another good day in the shop. Got the cage interior finished. Now I just need to finish the frame tie ins. I decided to go a little bit different with gusset tubes.
Put on the gaskets for the hard top sides from the SOR hard top gasket kit.
Cage looks awesome
Sadly, I have no updates except to report I have a bunch of boxes with a bunch of new parts ready to go on. Work and bad weather is just eating up wrenching time. the first sunny day that appears, the game is afoot!
