For Sale Seattle WA; 1978 parting 2F, 4 speed and transfer case (2 Viewers)
Woodway, WA 98020
  1. 40 Series
1978 2F FJ40 engine, saginaw pump, high torque starter, all accessories + 4 speed trans + 4 speed transfer case.
IBurning oil and some valves are leaking. Started cutting out on me while driving. Around my property low speeds its fine. Leakdown test is no bueno. Time for a full rebuild and I'm repowering.
Separating out everything. Let me know what you need. FI system is sold
Engine serial is 227359. I put it in the registry on Mud
yes, that's the carb cooling fan housing converted to my intake snorkel adapter
You've mounted the MAP sensor lower than the throttle body, it must be mounted higher/above the throttle body, that might make the rig run better ???.
Price drop $1400. Planning on pulling in the next 2 weeks and palletizing the engine and trans/transfer separately so I can fork with tractor
History has shown that you will make a lot more $$$ if you part out. With that said, I'd be interested in a price on the complete fuel injection system, and the power steering pump/mounting bracket/pulley system, lemme know. And my guess is you would easily cross your $1400 threshold when selling the 4 speed tranny/transfer- - -easy deal.
SOLD
Downey FI pulled $300. What you see is what you get. Couple notes, I think one of 3 computers is NFG, 1 plug wire is broken, at the fuse block I had tied in the cars power and cut it off so you'll probably need a new block or similar. I don't know if it was something in the ignition or my flat wore out engine but it was hard starting
send me your email address, I want to see if I can use a different credit card to pay you. My checking account and debit card are presently screwed up due to a costly $3,000.00 mistake a restaurant made.
Is the camshaft stock, or a regrind?
sold items include
  • fuel injection
  • rocker assembly
  • valve cover
  • water pump pulley
  • alternator bracket and engine hook
still have
  • fan - $30
  • fan clutch (almost new aisin) - $30
  • water pump - $10
  • radiator - $40
  • hi torque, gear reduction starter (almost new) - $60
  • head 61031 casting - $100
  • block
  • crank
  • rods
  • pistons
  • cam - pending measurements
  • oil pan - $20
  • bellhousing shield - $80
  • flywheel - $60
  • bellhousing - $100
  • 4 speed trans - $300
  • transfercase with new ebrake and seal - $300
  • nick nacks - ask
Or make offer. Somethings like the block, crank, pistons, etc I plan on cleaning up, measure and post photos. Unless your local, zip 98020, and want a looksie
Interested in the bellhousing and harmonic balancer shipped to my shop, 91502
The balancer IMO is fine but the last folks to install the timing cover did so non-concentric to the pulley. The lip seal surface is fine but the threaded oil slinger (?) was riding the pulley. I'd just assume to clean this up so it doesn't damage the lip seal on install. How's $80 for the balancer sound? Shipping will be UPS from 98020. Can you DM me as I can't seem to be able to DM you...
  • Back
