Seat tracks - not gears
I’ve done the gamiviti fix many times over the years but trying to make factory auto seat into manual without using the nuts on front of seat each time. Have an extra corbeau manual seat mount/bracket. BUT, how do you get the factory bottom rails that bolt to floor to slide out of their mating channels that bolt to the seat assembly?
I think there is either a pressed or welded tab in the bottom track that keeps them from being separated. It’s been a long time but I think I drilled it out to get them apart.
Thanks. So accessed between the track and the seat cushion? I’ll pull the seat cushion off and see if it is obvious what it is that is the stopper pin or whatever.
You need to separate the rails when you do my seat bracket install. The only way is to drill out the rivets on the front feet and remove g to he feet. The bottom rail will then slide out to the rear. Read through the install guide for my seat brackets on my web site to see how it’s done.
