SOLD SE Michigan 1995 Toyota FZJ80
Year
1995
  1. 80 Series
Mileage
146000
Color
blue
It's with a heavy heart that I’m selling my 80 Series that was built to be my ultimate “dad wagon”. It’s been used to go on adventures into Michigan’s UP as well as some pleasure drives around town. It’s a comfortable, reliable, adventure machine. But life often takes twists and turns that we don't expect, so it's time to part with my 80.
With 146,000mi, it has tons of life left to live and one of the lowest mileage 80’s out there. The paint is admittedly on the “patina” side of the spectrum but that’s what is great about this truck! It’s nice enough that it will last forever, and you don’t have to worry about the paint with small children or out on the trail! The truck has been upfitted with a OME 2.5” lift, 33” Falken tires, and an Ironman4x4 bumper & winch. I have serviced most if not all of the systems on this truck and it is ready to face whatever you want to throw at it!
It's not perfect, but I trust it to drive anywhere.
Please reach out with any picture / video requests!
146,000mi
$22,000 sale price Oct 2024
Originally a SC truck (no MI winters)
Modifications
•OME 2.5” Lift with heavy front springs & medium rear springs
•30mm front spring spacers
•Control arm drop brackets
•Caster correction bushings
•Extended sway bar links
•Extended SS brake hoses
•Extended axle brathers
•Center diff lock button
•33” Falken Wildpeak AT/4W
•Ironman4x4 bumper w/ LED fog lights
•Ironman4x4 10,000lb winch.
sealed, synthetic cable
•Magnaflow catalytic converters
•Borla Exhaust
•Monstaliner white roof
•Rhino-Rack load bars
•Apple Carplay Boss radio
•Pioneer door speakers
•Midland radio mount & antenna wire
•Heated front seats
•Rear spoiler delete
•Bondi Blue Stripe kit
Repairs
•Engine tune-up (spark plugs, wires, distributor cap & rotor, ignition coil, valve cover gasket & seals, throttle body clean, belts)
•Rear main seal replaced
•Transmission replaced
•Radiator & thermostat replaced
•Rear heater hoses replaced by prior owner
•AC system replaced (compressor, condenser, drier, belt, fluid)
•New alternator
•Axle fluids changed
•Tcase fluid changed
•Birfields freshened up
•New brake pads & coated rotors
•New driveshaft u-joints & front drive shaft
•New tie rod ends
•Rear hatch struts replaced
•New windshield
•Sunroof sealed & disabled
•Sylvania Silverstar headlight bulbs
•Replaced seats for an original set in better shape
•Replaced Driver’s door window switch
Unaddressed
- CEL on (Knock Sensor)
- ABS light on
I have some spare parts if you want them as well
