NorCalFJ100
I read through the heated seat with OEM switch install thread 97' FZJ80 heated seat install with Toyota horizontal low/high switches
I also searched quite a bit. I am a total electrical beginner so I may have misses the answer somewhere.
I see the three wires on the OEM switches that control the Hi / Low / Ground, per the thread above.
First question, since I do not have OEM seats any longer, can I just tap directly into those wires?
There is a power and neutral wire for each heating element of course. My SM Seats came with a ready to go harness, but I am of course not using that since I have the OEM switches. I have taken the heating element connection wires and separated that from the rest of the harness. See pictures below. There is a black ground wire on one and a black wire with yellow stripe ground wire on the other. The 12V+ wire loops from one connector to the other, then one 12V+ comes out of that.
Second question, do I combine the two grounds and tap into the appropriate ground wire on the switch harness itself? Then for the single 12V+ wire I have, do I splice in a 2nd wire and feed that to the appropriate 12V+ Hi / Low connection on the switch harness?
I really hope this makes sense. If not, please ask away. My truck is all torn apart and want to get it back together tomorrow.
