I'd get the connectors that mate to the OEM harness. Look on the back of the connector housing, there's a 5 digit number embossed there. Get a copy of the Wiring Harness Repair Manual (it's in the 80 series section of the Resources forum), and search for that number. There's a matrix that lists the male/female combinations. You can get the part number for the mating housing from there.After reading through all the threads on after-market seat heaters, I'm looking for some help on this. Here's my setup:
Do I use the OEM seat heater plugs and OEM switch and just splice the SM wires into that? If so, would someone please help me connect the dots between OEM and SM?
- FZJ80 with OEM seat heater plugs (not in use currently).
- Scheel-Mann heated seats fully wired direct to the battery with appropriate fusing and relays.
- OEM switches from Japan (84751-60010, 84751-60020)
@Feldrian kindly posted the following for the OEM harness [() denotes RHS]:
Pin 2 (1) - +12V
Pin 7 (5) - Hi signal (to SM harness)
Pin 5 (3) - Low signal (to SM harness)
Pin 6 (4) - ground
Pin 3 (2) - backlight
Pin 6 (8) - backlight ground
SM (see pics)
Red/Orange (1)
Red (2)
Red Blue (3)
Black (7)
Now you need terminals. My recommendation is Ballenger Motorsports.
Check that the connector housings use Type II terminals; I think they do, but check anyway. That info is also in the Harness Manual, in the front; flip through the housings and you'll see what you need.
They also have a terminal crimper. I like this one, but you can use whatever you'd like.
HTH
