- Joined
- Dec 13, 2008
- Threads
- 27
- Messages
- 1,222
Cool, though, I think the FJ by itself limits how far you can push it. Don't expect sharp turning, don't expect to drag race between lights, or go vertical (though that sure as hell can be fun).
So it truly is to try and get everything out of the FJ. Thank you for supporting this thread.
...Buy a Porsche...a Corvette, and a motorcycle. Problem solved.
this thread is all over the place...
...Ain't that a fact!
It bounces from one "problem/solution" to another.
We've gone from what do you think of the SBC v. the 2f, to the Mercedes Benz engine, to f**king autocrossing and street racing
Is there really a point to the thread, or is this controlled by a bot?
IF... a 2 f is properly cared for it will outlast any small block 3 to 1. Yes... the small block has more Horsepower.. the 2 f has more torque. the 2 f runs cooler, and CAN be built to have nearly the same horsepower as a mild small block. I like both, and the only reason my 40 has a small block, is because it was cheaper than building a nice 2 f.
I'd have to disagree with your assessment of the 2f outlasting the SBC. If both are equally maintained, I doubt seriously the 2f will outlast the SBC without more extensive maintenance at some point.
The newer LS engines when properly maintained, are good for a couple hundred thousand easily. Refresh, and start all over. Rebuild/refresh costs? About the same, maybe slightly less for the SBC.
IIRC, they both make good torque, just at different RPM ranges. The SBC is designed to rev higher. I had an L98 in an 87 corvette. They didn't call it a "Tourqe monster" for nothing
Two things I'd like to see when building the 2f to match a "mild" SBC.
1) the longevity after the build.
2) the cost sheet.
Drop that same money in a SBC, and there's no comparison on either. As you said, it's cheaper to build the SBC
