So I have a SBC 400 with about 108k on the rebuild. I runs pretty good, some pings at WOT but strong other than that. I just changed the rear diff and xfer case fluid and noticed oil coating the under side of all the running gear. I have traced it back to the timing cover/oil seal.
Question: While i tear into this should I replace some more of the bolt on stuff, pwr steering pump, pulley to wide serpentine pulleys etc? The parts are old and could be replaced as well as hoses and just general clean up.
Should I even get into it or just get another motor? I know is sounds crazy but how many more miles can I get on a rebuild?
This is my first rebuild so I really don't know what to expect. I would guess if done properly it should last just as long as a new motor if taken care of but judging by some of the decisions made by the previous owner, I am a nervous.
Should I just fix the seal and run it.
Thanks for the input on what you would do.
