Ok, so, my OEM power steering pump is on its way out, and it seems like a saginaw conversion would be a way better option than replacing the OEM pump. So, I've read up on the various ways people have done their saginaw conversions, and I'm trying to figure out what the shortest path between two points is for me...
Here's what I know:
- I'm planning on doing a full desmog and get a Jim C. dissy recurve in the relatively near future. Mostly to simplify my setup and get it running better for cheaper than replacing all the marginal components. Plus, the cruiser is old enough that I won't ever have to emissions test it, even if I move to a part of the state that _does_ emissions.
- My alternator has a pulley meant for a narrow belt, but the slots on my power steering pump and the main engine pulley are both wide ones. WTF?
- I only have limited fabrication capacity. Think 'small oxyacetylene torch, access to a friend's drill press, taps/dies, and a horrible Harbor Freight angle grinder'. So, limited brazing, and removing of metal, I can do; building a whole bracket, not so much.
- I have a lot of free time, and not a lot of money.
So, here are my actual questions:
1. Everything I've seen seems to point toward an 82ish Volvo 240 being the ideal donor vehicle, due to the hose fittings matching, and the pulley style. Is this true?
2. How good is the MAF Saginaw bracket, the one for the 2F, that bolts on with two head bolts? All I've been able to figure out is that it's kinda pricey ($170), and that it's problematic if you haven't desmogged. If the quality is good, and it's an easy fit when the smog pump and hard vac lines are out of the way, it seems like it could be worth all the saved time.
3. What's better: junkyard pump for $50, say, or a rebuilt one (with no core charge) for $100ish? I'm having trouble finding a brand new one anywhere online.
4. Does anyone have more pictures of This type of mounting solution? I can't find anything that clearly shows how it works with the stock bracket in back (towards the firewall).
Here's what I know:
