Well, I finally got tired of the leaky, noisy Toyota PS pump. I've put two Napa pumps in and both lasted less than six months, killing two air pumps in the process. I really wanted to fit a Saginaw pump in my rig but I also needed to keep my air pump since my county requires me to pass emissions. So, I took the plunge and spent a day making this work. Fortunately I have a brother who works as a machinist at a hydraulic shop!
Here's the donor pump, pulled from a Jeep Cherokee in a wrecking yard for $30.
We wanted to use the OEM bracket if we could but obviously the holes wouldn't line up. The first thing we did was create an adapter bracket to try to bridge two of the mounting holes on the pump to one of the holes on the Toyota bracket. We came up with this. The hole in the middle is threaded.
As we were mounting the pump we noticed that we had to take a notch out of the Toyota bracket to allow clearance for the Sagniaw.
continued....
continued....
