Sag pitman arm rod end info request
scotia
Houston Tx
Hey all
I wouldlike to replace the saginaw pitman arm tie rod end. Does anyone have a part number for one that can be purchased at a local parts house?
This will be for a stock steering rod on my 40 to the pitman arm. I did not want to wait around to oder one from the popular guys. No offense though as time is an issue. Thanks
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
These two separate statements in your question do not add up.
How do you have a stock steering rod on your 40 series connecting to the Saginaw pitman arm?
I am not aware of a metric tie rod end piece that threads into the original Land Cruiser drag link from the tie rod to the Saginaw pitman arm. Along with the thread issues of the stock steering rod when trying to use the correct piece for a Saginaw pitman arm, I am not aware of a stock steering rod that was on the 40 series that would be close to the proper length. Further, the taper of the Land Cruiser tie rod end does not get secure into the taper of the Saginaw pitman arm.
:meh:
Josie'sLandCruiser
Stop calling it a "FJ."
Seattle, USA
Hi All:
I would suggest pulling the existing TRE connected to the Saginaw pitman arm and take it into a good auto parts store and start trying to find a match.
Start trying the TRE end for a GM one-ton pick-up, or a Jeep J20 pick-up, etc.
Good luck!
Alan
Hey all
In the redwoods
I had that same set up. My po set it up and I had problems with the whole set up staying tight. I tried pressing bushings in and when that didn't work I made some shims and added them to no avail. Same with the arm on the ps side. After every run it was loose. I ended up re tapering all my arms with heavier ends and rods.
scotia
Houston Tx
As it turns out, it is a downey drag link. So with that said....any local parts house part numbers for a new rod end? Maybe a year make and model that will work?
Poser
s-Moderator
Supporting Vendor
MN
1979 CJ-7 with power steering...
shelfboy1
erie pa
back in the 70s we used a 70 olds cutlass pitman arm and it worked fine on a stock 40.i believe this was the recomended arm in the manafree catalog .downey used a tie rod threaded metric on 1 end and american thread on the other.either way both kits bolted up good luck
