So finally have another day to work on the cruiser, addressing the oil burning with a turbo rebuild.
A few weeks ago my friend Ken lent me a compression tester to get that out of the way, luckily the compression was still good, #1 was a bit low as far as compared to the highest pressure, but it was still at 485, compared to the minimum allowed spec of 384. The other cylinders ranged up to 560, everything was quite healthy.
While at it, I noticed that the turbo was starting to give me some visual signs of badness:
So, ordered the rebuild parts and sat on them for awhile.
Today rolled around, got to work, started with draining the coolant and I remembered that I never posted a pic of this little mod:
It's just an extension tube from the drain port on the rad with a plug in the end.
Drains right into a bucket without a drop spilled.
On to the turbo:
Here is the turbo before rebuild, disturbing bit of wobble:
And after the rebuild, really disturbing bit of wobble:
I just posted up a thread in the diesel section for some advice on the condition:
https://forum.ih8mud.com/diesel-tech-24-volts-systems/605157-advice-condition-turbo-thanks.html
Not sure wether to re-install or not.
