Are you re-using the coolant? That would actually be possible since its not going all over your floor.
The reason I ask is; Toyota coolant is expensive stuff.
kevinmrowland said:Yeah, I usually re-use it, run it though a paint filter on the way back in, have always done that.
Thanks Jason, I like the cap test idea, hadn't thought of that, I usually just pull the vent line and give it a feel.
Gave it a shot, nothing really obvious though, couldn't really get the cap to move except to kind of wiggle in place as the idle re stabilizes after a punch:
Hi kevin. Love your car and wagon gear.
Do a leak down test to get your answer. I wote for valve seal oil leak.
) I modified my compression tester to pressurize the cylinders with some air, will see if I can find some leaks that way, might get to it tonight.Thanks Ward, nice to know I can count on you to look out for number-one.I am voting for a cheap/easy fix so Kevin can spend his time producing gear for my addiction - after the vacation, of course.
Yup, (and thanks! and welcome to Mud!) I modified my compression tester to pressurize the cylinders with some air, will see if I can find some leaks that way, might get to it tonight.
You've got plenty to do with taking care of the new WA house!
60 series meet-up at Wards new house everyone!
KR
