Rust Converter & THEN FluidFilm/Woolwax??
new york
I’ve recently purchased an 01’ LX470 and although very clean frame, there’s still SOME rust of course. I’ve been reading through lots of threads on which rust converters are best, the pros and cons of fluid film vs woolwax, which is all helpful.
But the one thing I’m still unclear about (and maybe this is a stupid question) is whether it would be prudent to use a rust converter and THEN use fluidfilm or woolwax, or if it’s fine to just go straight ahead with the FF/WW. If it was a brand new car I’d obvious just go straight to FF/WW, but if I just use that now without a rust converter am I locking in rust and not doing myself any favors?
The idea of fluid film is to not trap moisture like paint or old fashioned undercoatings do if you apply them directly to rust. I haven't tried it so I don't know how well it works though. Just plain oil works just as well, but will need reapplying more often. That's what I do on all my vehicles, the local shop charges 70€ for spraying and it needs to be done approximately once every two years. If you use rust converter I'd put some paint over the converted areas before applying fluid film or oil, just to get an additional layer of protection.
I'm planning on using this on my 40, when the body comes off later next month.
CorrVerter Rust Primer
It's spendy, but I do not want to do this job twice, and I have other sheetmetal that needs it.
I'd rather use Corroless, but I can't find it in the states.
I'm also pondering this. What about doing POR15 / Rust Bullet on the exterior of the frame and FF/WW on the interior of the frame?
That's the best you can do unless you have access to acid dipping and paint dipping or galvanising, to get the inside painted. I was planning to get my frame painted with epoxy primer on the outside and sprayed with oil on the inside, but I found a galvanising place that's cheaper.
I definitely don’t have those options available! Seems like you would apply the rust converter and let that cure really good before spraying the inside of the frame. This approach seems like it would avoid the concern about getting the film spray on rubber and connections.
