Running rear wheel bearings in diff oil.
I switched rear bearings to oil about 2,500 miles ago; no leaks and everything's still tight. I really like to use of cap screws too as the cone washers dont require a brass drift to coax them out. Replaced the front studs with cap screws too.
Sorry if I wasn't clear; I'm still using the OEM cone washers and flat washers, but with CL 12.9 cap screws instead of OEM studs. Fronts are M8 -1.25 x 30 and rears are 1.25 x 28.5 (+/-). Disassembly is easier ...and they look kinda techie. ⚙️
I put a 80 series rear axle in the rear of my fj40 a few years ago. I broke a left rear axle shaft last year. My fj40 has 35" tires and a 2f engine. I used to run cheap aftermarket u-joints so that the ujoints were the weak link. I replaced the ujoints with factory ones and now I guess the axle shafts are the weak link. I was trying to crawl up a rock and I was more bound up than I thought. The scenario of running without the shafts in the hub would be if I damaged the differential somehow. I've never damaged the differential on this axle so far.
Interesting and only experienced this with older model cruisers. But then again we do not do much rock climbing!
