Hmm. Im curious what you find with the old turbo.
I crammed a valve stem over the port to my wastegate actuator, then filled with a tire chuck that has a pressure dial on it to see when it started to stroke. The actual pressure it starts to move based on how much tension is put on it, how much force from is on the wastegate flapper valve in the housing wanting to push it open etc.
It gave me a baseline before I swap the H1C for the HX35W, but I bring it up as a method of checking what you got.
Im starting to think the issue is with the waste gate, a bad seal somehow where air is bypassing, or some sort of mechanical conflict against the arm or something. Who knows maybe you find a piece of an exhaust seal in there somewhere.
Best of luck.
Best of luck.
