- Thread starter
- #21
Gas: I've changed out the filter, so that ain't it.
Ignition: I pulled a couple of plugs last night and one was wet, gas wet, not oil wet. I'll pull the others tonight & report back. I am going to get a new distributor seal, then follow the FSM to "reset" the distributor. Also, change out the plugs. I'll report back once done.
Codes: Got a 51 which says AC and other stuff. I don't use my AC, so I'll bet that's it. If the ignition changes don't fix the problem, I'll dwelve into the 51 code further.
Mr. Prick, just kidding. I've solved a couple of issues on the Mud and someone get's a little curt by the end of it. You have to take into consideration my ignorance. This ignorance is why I post stuff here so I don't go out and spend a butt load of $ to fix EVERYTHING but the problem.
Mr. Timing, That attachement looks like it's from a 1967 Pontiac. The FSM & pictures on the Mud have the timing window near the firewall, like it's looking at the starter flywheel. And YES I saw a bolt head. Hopefully after I reset the timing, I'll be able to see some dots like the FSM says.
More info coming.
More info coming.
