Rough Country 16x8 -12 offset
NC
Does anyone know if these will fit a 96 80 series. I'm looking to replace my. Fj steelies and spacers for these. Any opinions would be appreciated.
Thanks
Just an FYI I ordered one of these wheels to check fitment. Fit fine on the front and rear, clearing both calipers with room to spare. I'll be ordering the other four soon.
I've only ordered one to try so far. I'll probably buy 4 more when funds allow.
Different make, but a '93 on 285-75s w/flares, 16x8 -12 offset.
Don't imagine a '96 would present a difference.
Yeah that's a perfect fit with the -12 offset. Do you have any rubbing at all on the flares? I wouldn't think so since it really doesn't poke out much further than stock wheels. Look great!
No, none. Even when fully tucked.
Forgot to mention, they are 4.25" backspace so no spacers either.
Did the center caps giving you any trouble? Wasn't sure if they would work with the full float rear axle?
No, they are a perfect fit. Maybe a couple thousandths clearance?
If anything taking them off is a bit of a kerfuffle. Pretty thin metal, easily dented whacking with a mallet.
Be gentle.
I pulled one once during a tire rotation. Saw what looked like diff oil leaking down the inside of the tire.
Had been a couple thousand miles since a knuckle rebuild and wanted to check the flange gasket.
Turns out it was dog piss from a stray living in the complex. :facepalm:
FWIW, these are they except w/4.25"BS (these are 4" I think). Also looks like they've updated the center caps. Look better than what I have.
OK good. I wasn't going to order the center caps when I ordered the wheels by I'll try them to see if they'll fit. They aren't expensive, so if they don't work it's not that big of a deal.
Yeah, since you made me look lol I'm tempted to get the new center caps for mine. They look alot better than what mine came with.
