the problem i am having is when i ordered the kit i apparently ordered the flat pitman arm VS. the dropped arm like i was wanting, TG said they would swap em for me if i shipped it back but that was a year ago and i have not done it yet. need to contact them and see if they are still willing to do this or not.
now the bigger problem is the 60 series factory pitman arm has a larger bore than the drag link end does on the TG kit so much so that the nut will bottom out before the end is even snug at all.
If i can get TG to swap my pitman arms they will match and problem solved, If I cannot i need to find a solution.
so any ideas on how to make the 60 arm fit the end i have now? im pulling a total blank on this and would rather not have to try and track down a TRE with the same thread pitch as the one used by TG and then also having it match the pitman.
Call Luke at 4x4Labs. He makes a cone spacer to fit over the 80 TRE to make it the same thread pitch as the 60 TRE so you can use your stock pitman arm. It's not listed on his website so you have to call directly. All of that is outlined somewhere in my thread.
