Rooftop tents... what do you think??
expeditionswest said:
Super 70's unit looks very similar to the Eezi-Awn. One of the things that makes the Eezi-Awn very easy to store is the internal tension straps. They pull the sides in towards the middle as the unit is closing, preventing all of the loose material from spilling out.
My cover is also pretty slick, as it was a built in ratchet strap that pulls everything tight.
DD and I should be able to give a solid review of both units after our Baja trip. Over two weeks to Cabo and back on dirt roads...
Yeah... mine has the same internal tension straps on both ends to pull all the material in when closing the tent... basically bungie type straps with clip together plastic buckles. My cover also has the built in rachet strap... to cinch the cover tight over the tent when in stored mode / for driving.
I agree... looks very similiar to the Eezi-Awn although I haven't seen one right up close.
Look forward to reading your reviews.
:cheers:
Hey guys this is my first post on here and hope its welcome. I noticed you guys were talking about the Mombasa rooftop tent and I had gotten one for my SUV and never ended up using it. I am now moving to a new house and the wife wants the big box out of the garage and not to move with us as I now have a truck and no use for the tent anymore. To make it short I need to get rid of it and would let it go for $400, its brand new in the box and someone can get a great deal. I am in So Cal so not sure on the shipping it would have to go freight or be picked up. Feel free to email me and I can send pics if needed krgdesigns@yahoo.com or message me for my cell #. Thanks
Ken
super 70, nice trailer set up! Does anyone have pics and info on doing something similar on a military trailer? I will need to set up the tent on a trailer as in the fall I spend a lot of time chasing elk and the FJ will be used to get a little further away from the camping area.
attachment.php
I have a 4th gen 4runner.. I assumed I would need a new rack system to get a rooftop tent but after seeing that photo, I'm not so sure.
http://www.autohomeus.com/choose/index.php
On that page it talks about rack ratings and the correct tent.. do the rack ratings only apply while the truck is moving?
Most manufacturer's ratings are for a "dynamic" or moving load. Static, or stopped loads are usually greater, but, I would try and see how the stock rack is mounted to the roof...don't want dents where the feet are. :doh:
-H-
I'm enjoying my roof top experience very much! It's a simple tent made by Car-top-tent but I don't this particular one is being made any more. It's fairly lightweight at 60 lbs or so. The biggest thing I did for this trip is to build a sturdy wind fairing for it and it has paid off handsomely. It's very quiet at hwy speeds.
Here're couple of pics:
Ali
SinCity4r said:
attachment.php
I`ve had a lot of experience with OE Toyota roof racks, and regardless of "load ratings" I wouldnt trust the stock rack when using a roof-top tent unless the load is somehow placed OFF the cross bars.
IMO the (stock) rack and bars are not up to the task of regularly supporting 2 adults and even the lightest weight tent.
I would still consider putting a sturdy aftermarket rack up there that can be configured to handle a variety of loads.. I finally went with an African Outback Rack after constantly worrying about overloading my OE rack. :)
alia176
Alia176, can you post pics and info on making the fairing??
When we talk to customers about roof racks and cross bars, we often find a lot of confusion over the following three points...
1. Dynamic load limits vs. absolute load limits. Rack systems sold in the USA almost always specify the DYNAMIC load limit. This is much more about vehcile handling and braking than the strength of the vehicle roof. Very few vehicles sold in the USA have a dynamic load limit of more than 165lbs. All Landcruisers are rated at 165 lbs dynamic roof load.
When stationary, vehicles can support hundreds of pounds - four people and a tent on a roof mounted rack system is not too much. The rack system carries the weight to the strongest part of the roof.
2. This DOES NOT MEAN THAT THE FACTORY RACK AND CROSSBARS WILL CARRY THAT WEIGHT. Almost all factory crossbars are marginal for any weight beyond a pair of skis or similar. The factory towers and rails on most vehicles are quite strong, but the crossbars may not be. We almost always end up recommending Thule, Yakima or other engineered crossbars for mounting AutoHome tents on customer vehicles. We have had zero reported failures with Thule or Yakima bars carrying our tents.
3. Functional considerations. Some people I talk to have ordered the coolest, baddest expedition basket that can be found - the rack itself often exceeding the dynamic load limt of their vehicle. When they ask advice on how to fit a tent, I often need to tell them that the cool rack has to come off, or be fitted with cross bars that can carry the tent. Very few baskets have the interior width to carry any but the smallest tents. I always hate to do this, and I like these baskets for the use intended - loads of gear to be carried across the Sahara or the Australian outback.
In any case, a bit of pre-planning and consideration of actual needs is the best approach that I can offer to the potential buyer.
Mike S
I don't think you'd be able to change the OEM crossbars. Yakima A towers will clear the stock rack. Stock racks have been known (at least on 80 series trucks) to be a point where rust can begin, so many of us have taken them off and cleaned up the areas where they originally mounted, then reinstalled them or otherwise left them off.
I just left mine off, as my Con-Fer rack has been "lowered" to fit into a 7' garage, and there was not room for the stock rack.
-H-
As MikeS mentioned, the cross bars are the weak point with the OE rack.
The supports that run length-wise are quite stout and are capable of taking a fairly decent load, so its a matter of finding the right aftermarket cross load-bars/brackets to attach to those side rails...
I personally would still remove the ENTIRE stock rack though.... :D
SinCity4r said:
Thanks for the info guys.
As far as the cross bars on an OEM toyota rack, can they changed while keeping the towers/rails or should the whole thing come off in favor of something else?
As noted above, the side rails on the '04 4Runner are quite strong. Thule makes a foot (Crossroad 450) that clamps to the side rails, and will carry a standard 58" Thule crossbar (LB58). This is a simple, strong, and removeable set up. Rated at 165 lbs, dynamic load limit.
I believe that the factory crossbars can be removed.
Go for it.
M
Whould two lb58 crossbars be sufficient?
Thanks for your help Mike.
