Not really..@RIVAL 4x4 You guys have any plans to import that hood?
We only deal with own RIVAL products
@RIVAL 4x4 any idea when the next batch of bumpers for a 2013 LC will be available?
Glad my friend and I ordered the last 2!From now it should be around 3 months.
I genuinely love mine. The fit and finish is awesome, fits the body lines well and has treated me well off road. I swapped from an ARB bumper and I can tell a big difference in how the truck performs due to weight (steering is lighter, less movement over bumps).@jeep2cruiser and @grinchy (and anyone else running this bumper) now that you guys have had it for a little while, are you still happy with it overall? Was going to DM and ask the same, but figured others might be interested as well.
For the trim piece, make sure that the metal inside the trim is what’s clamping onto the the designated spot. To keep mine from coming up, I put a pea sized dot of super glue. Haven’t had an issue since.I like the look of it, but do have some issues with it.
- The Headlight washer nozzles didn't fit correctly. I ended up snapping some of the plastic ears off of each one of the squirters. The problem is that the aluminum is too thick for the snap features to work correctly. Also, one of the metal mounting tabs didn't line up with the corresponding tab on the squirter assembly.
- I seem to have some metal-to-metal rubbing on mine even with a good-sized gap. I need to adjust it some more.
- The edge trim that was included with the bumper comes off too easily. I ended up removing it and might swap in a different profile.
