orangefj45
Supporting Vendor
- Thread starter
- #101
when i was cleaning up the workbench i found a cruiser t-case idler ger so here's a pic of it and it's atlas counterpart( on the right):
woody said:I like that bracket for the OBA setup...tho I've used the stock Harrison pancake for years with no problems
are you running serps, and how does their kit deal with that?? How is the height of the compressor relative to the hood?
HI^C said:Well i was playin in moab to much and missed a bunch
89 or earlier dodge d60 cut 4" like 63 to 63.5" wms
Which last time i was playin with measurements i believe would still land you
on stock springs?
DID you cut and turn the other side while you had the one off???? sorry if i could not
catch it earlier. Dodge runs the least amount of caster in all their d60s. Stock is 2 degrees!!!
We run a 4runner on 40's or 44's with 2 degrees and it does 55mph without problems and actually steers better then any of my cruisers.
long front driveshaft will probably be ok, with the low pinion angle.
pre 89 housing still should have a 16" short axle? and they are neckdown inners? I seem to only play with chevy or a few late dodge housings.
having a hard time finding 35 spline flanges or lockouts?? let me know i will see if a guy is still making them.
