Thanks for the feedback. I used paint from Cruiser Corps. They have it in rattle can. As for the window, there is a small hole about 1/2 of the way down. It’s not near the top.The Weasel (synonyms - scoundrel, wretch, rogue) is perfect name given the bib plastic filler and tub discoveries. The cluster turned out perfectly...what paint did you use for it? Also, question on the window frame. Is there a small hole at top left of window frame just before it curves down? My truck does not have it and installing OEM dome light and loom and wondering if that’s where it was routed on a 76....
Thanks. Is it half way down on the inside or outside of frame? Below is image of my windshield. If you can snap a photo that would be helpful. The dome light loom comes up the windshield frame from harness and then out that hole with grommet and a barrel connector.Thanks for the feedback. I used paint from Cruiser Corps. They have it in rattle can. As for the window, there is a small hole about 1/2 of the way down. It’s not near the top.
thanks. I’m going to post final build pics. FJ40 is currently at the speed shop getting final carb setup and tuning.
