staggrlee
GOLD Star
My door cards are generally in very good shape but the PO had removed the vapor barrier from the driver's door and it had gotten wet at some point causing the card to warp and bow pretty severely at the base of the card farthest from the hinge.
I'd ordered a new master switch and removed the card to install it and decided I'd try to correct that. I removed the map pocket and after a shampoo of the fabric areas, I placed a wet, wrung out towel over the back of the pressboard and hit it with a very hot iron until the board was good and damp, but not wet.
Sandwiched the card between some boards and weighted it down overnight and it's now back to 90%. There was no way to get the speaker grill off without destroying it so I couldn't get even pressure across the entire lower portion of the card so there's still a bit of bow there but clips and grab handle should snug it up. Worth a try before chucking a door card and replacing.
