Request for images / wire trace (1 Viewer)
Phoenix
Good evening guys! I am so close to finishing my factory A/C install in my non AC 83 60. New hoses are being made as we speak!
I could use some help identifying the location of some wires.
There are two wire bundles that come out of the firewall next to the evaporator. One wire goes to the A/C compressor. I need help finding where the second (two wires) wire runs to.
If anyone can help me out I’d appreciate it. Pictures would also be very helpful.
Thanks!
Jeff
I don’t have a diagram for you, but if you’re referring to A/C wiring on the engine side of the firewall the additional wires probably go to a low pressure switch attached to a low pressure hose.
Maybe this will help
Looking at the above circuit, a black with white stripe wire goes to the magnetic clutch #10 in the image and would be on the compressor. And blue with black stripe and yellow with green stripe wires go to a VSV or vacuum switching valve #8 in the image. The VSV looks like this:
and is on the drivers side fender well. There are 2 vsv's but you prob could id by the wire colors going to them.
the other wires are W/B goes to ground, and a black wire goes to coil
Is the VSV necessary for the AC system to function? Wires are Blu/Blk Yell/Green.
I have a non ac 60 so I don’t have a VSV. I am using a sniper so I’m not worried about idle up.
If it is required can I bypass it?
