Repurposing the AHC/RAHC switches for crawl control. (1 Viewer)
Washington
Since I no longer have air suspension or adjustable shocks, I'd like to see if i can use those switches for crawl control. From what I've been reading if I de-pin wire 16 and plug it in wire into pin 6 that should turn crawl control on and off. Can anyone confirm that? Also what pins would I re-pin to be able to select the speed of crawl control? Thanks!
This is something I've been wanting to do for some time.
All the info to do it is on CL.
My idea is to use one of the switches as an ON/OFF, which would be to repurpose the two position toggle. Then use the factory self centering momentary switch to select crawl speed.
The wiring for the module plug is already there, all one needs are switches. If you're handy with a soldering iron and pay attention to what you're doing it should not be too hard.
I keep threatening to do it, but never find the time. I have the M/T but I want to get this CC going too.
I can indeed confirm that taking wire 16 and pinning it into 6 does turn the OFF button into the crawl control button. Now I just need to figure out the toggle switch for changing the speed for crawl control.
I believe changing the speed is a "momentary" switch/button, not one that you switch to each speed.
