I recently noticed that the spring bolts were not centered in the bushings, and it got me thinking that they may be worn out.
After canvassing the club members for opinions I decided to go with OEM rubber instead of the more popular and colourful polyurethane ones.
CDan came through with genuine toyota bushing for a measily $3.65 each. It worked out to about $5 each delivered.
Last week I sprayed the bolts with PB Blaster and today I tore into it.
I jacked up the frame until the weight was off the wheels, and took the nuts off the shackle bolts. I then jacked up the axle until I could easily wiggle the shackle. At that point I used the plastic deadblow hammer and pounded the bolts through. I finished them off with the drift once they were flush with the shackle.
One of the pins was stuck, but a couple of good twists with the rachet lossened them up enough to push out.
Once the bolts were out, I pulled off the shackles and pryed out the old bushings. They needed to be replaced as you can see in the pictures. They were very ovaled.
I used a rattail file to clean dried mud and some rust flakes from the spring eyes and then coated them with grease. The bolts were in very good condition and I will reuse them. CDan reports they are unobtanium now anyway.
I fitted the new bushings and squeezed the shackles back over them. I used the drift to align the holes and slid them back through the springs. I used a small bottle jack between the spring and the frame to get the secong hole to line up.
I couldn'd find the torque spec for the spring bolts, so I set them at 50 ft/lbs. Anyone know if that is close to spec?
