- Thread starter
- #21
BMWSTOY,
Thanks to your tips, I was able to change the spark plugs myself. It is all done now. Took about two hours, but I enjoyed doing it and saved the $130 that the dealer was asking for.
Again, thanks for you description of the work.
Mine at 120K appeared to be in need of changing, although not too terrible.
The steps I used: Take off the air filter cover and then loosen at the intake and take off this entire piece to screws holding the cover near the hoses. Of course you have to take off the bling cover to the engine first. Then to get to the 4 pass sides, you are there with no worries. On the drivers side, I just unhooked the large electric plastic hose from the connectors - but I did not take off the mounting plate in the way of the 3rd plug back. The 4th plug back took a 2" extension and a 2" universal extension - if you have two 2 X 2's" or two 2 X 3's you should be alright. The longer extensions will get in your way.
Hint: When removing the coil, turn and wiggle with minimal force - pulling straight up did not do it. This was something that made me nervous after seeing how much those cost. Just a little wiggling and you can hear the pop from the rubber gasket.
IMHO - I did not use any compounds or lubricants - never have - the factory does not either from my understanding as I removed my NGK's and replaced them with Denso's. I am sure Toyota uses whatever brand won the bid that year between the 2. Easy job- and good for another 120K.
Cheers
