WarDamnEagle
- Thread starter
- #21
Well if anyone is contemplating ordering carpet from these guys; don't hesitate. I couldn't be happier. The color looks perfect now that it's installed.
A few suggestions:
I started with the middle section by cutting out the small rectangle for the center console and then attaching the inside front seatbelts. Make sure you have brand new box cutter blades. The carpet is easy to cut but the thick jute backing is just this side of impossible.
At the seats and the two floorboard seatbelt attachment points (just behind front seats) I cut the carpet out but made the holes a bit small and then crushed the edge of the carpet underneath the metal before bolting things down. It turned out pretty good. For the rollbar, I cut a slit to the edge of the tube (2" diameter) and then cut a 2" diameter hole. The carpet then laid over the mounting flange and bolts.
I removed the two radio bracket mounts that attach to the transmission hump in front of the center console and also removed the very bottom of the AC vent duct that basically touched the transmission hump. They were difficult to remove but it made the install much easier.
Again, I'm very pleased with how it turned out. A few photos (still missing back seats):
A few suggestions:
