One of the biggest problems is Ethanol hydroscopic and picks up water everywhere , if your just burning thru gas constantly its not going to be a problem with a modern car . The gasoline business is such a rip off .
There is a reason you can’t put E-10 in a aircraft it absorbs water and will freeze and you crash , but its fine for your car Or small engine .
I know a little about the fuel business ... most gas station franchise have can buy there lower grade gas from any fuel supplier and joe blow thinks there getting name brand gas .
I was at a dinner one day and watched a no brand fuel truck go from a BP gas station drive right across the street to a Sunoco and fuel them up .
Sunoco has not cracked fuel in over 10 years , they just buy the cheapest gas on the market and make there money off the food and snack store , thats why you have not seen Sunoco 94 in all those years they don’t make anything but specialty race fuels .
If your running your vehicle on a regular basis there is really not much choice out there and you really can tell what your getting these days .
Even when I do get Ethanol free gas at the pump I usually do the food dye test on a small sample just to make sure I’m really getting ethanol free , I have been using one station that has allways been pretty good with that .
The last biggest problem comes down to choice , Government should not be partnered with Ethanol business and mandate you use there products when they don’t force automakers to post a actually MPG Test using the gas the Government mandates you use 10%
When your Cheerios has Round Up weed killer in it and the USDA comes out and says its within expectable Toxic levels just because they partner with farmers to grow corn for gas that is totally wrong . Nature valley bars and Cheerios should post the warning Glyphosate in this product and may cause cancer ... this is public knowledge.
Sorry maybe slightly off topic but directly related to Ethanol thanks to growing corn for gas blending .
I am familiar with gasoline blends and third party retailers.
Just because you buy XOM, Sunoco, Phillips, BP, Chevron etc gas DOES NOT mean you're getting gas that they produced, refined, and are now selling.
Gas is sold from refineries on pipelines and blended together not only in the pipeline itself, but at distribution terminals - many of which are owned by much smaller companies. Tanker trucks then load up on the correct grade of gas and literally squirt a pre-determined amount of detergent into the tank based on where its going.
The majors all have their "proprietary" blend of additives that, in reality, are made by only a few companies to begin with.
Gasoline grades are regulated and must meet federal specifications. Refiners will sometimes sell higher octane fluid to mix with off-spec gasoline from another refiner that couldn't meet spec. Bottom line, it all ends up in the same tank and only becomes a "brand" of gas when the detergent is added to the tank at the final destination.
The biggest consideration I take into account is whether the gas is fresh or not. I only use Costco, or other high volume distributors, because I know the gas is not stagnant in storage for an excessive amount of time.
