Recent Cruiser performance (1 Viewer)
LandCruiserPhil
Peter Pan Syndrome
Supporting Vendor
Graham County, Arizona
Recently we loaded up our 1996 FZJ80 (7080lbs.) and headed out on a 4300-mile holiday to Glacier National Park. More than ½ of the miles were done on secondary highways and single lane roads. The Cruiser was able to maintain the speed limit under most condition with the help of my right foot and the Supercharger. I found that it performed the best with higher altitude and cold air a noticeable difference from the almost sea level and 100-degree plus temps that I live in. The best MPG was 15.3 and the worst 11.6 (normal MPG for around town) with an overall average of 13.5. Not the best MPG but we were very safe and comfortable – priceless. Water temp reached its peak (225 degrees) on a long uphill grade running a strong 75mph at midday in Utah. I frequently saw 210 degree on grades with normal running about 180-190. By the way with all the temperature fluctuation I experienced the factory gauge did little to no movement. Oil consumption (Mobile 1 0-40w) was zero with frequent highway RPM’s of 2800 plus. About 1200 miles into our trip I had a little issue with my starter (fawk in the middle of nowhere) but a call to IDAHODOUG from the Cruiser Assistance list provided me with the info I needed, made the necessary adjustment, and never look back. A big thanks to IDAHODOUG and sorry if I woke you. Other than that the Cruiser performed flawlessly as any proud Cruiser owner would expect.
As for Glacier – GO it is absolutely incredible you will not be disappointed. Make sure you see the Canadian side of the park it’s beautiful, less populated, trails are less traveled, and yes a lot more Bears. Canadian cost was about 30% less than the states except for Gas - $3.75/gal ouch! We arrived in Hungry Horse Montana on the 3rd of June a little to early and very cold for a flatlander – snow and rain with daytime temp in the 40-50 range. I would recommend June 15 as a start date before the crowds hit. Buy then end of June the people; traffic, and mosquitoes were really starting to show up- time to leave.
Phil
Phil,
glad you had a good time. I had a blast too on my trip through MT to Calgary. What surprised me is your average mpg vs mine. I was loaded down to 6700 lbs and my avg was 12 mpg. Maybe having a supercharger made you go light on the go peddle? Were you on the Power mode at all? Also, what're your tire size and diff gear ratio?
Ali
alia176 said:
Phil,
Ali
Never use the "Power Button" only the power foot or manual down shift. Don’t like to be passed. The S/C makes a lot of pwr above 2800 rpms so if you stay there or above you can go up any hill pretty ez as long as you watch EGT and water temp. Mileage and performance was a lot better once I was up North -I loved it. Normally 13mpg is the absolute tops for around here. I did find pumps with 92 octane tags on them if that could make a difference and if the 92 octane was for real?? Gears are 4.88 with 37"s requiring no spedo correction with that set up. Roof racks can take away a couple mpgs - do you have a rack?
Phil
Phil,
Glad to hear the machine finished the trip in style and comfort. No worries on wakin' me up - I found yakkin about 80s was a great way to start the day actually.
Next time you venture this way, you'll have to go up to Banff and then Jasper. IMHO, the area between these two cities and points north of Jasper are the most beautiful places on Earth. Simply stunning. And of course, this will put a stop here mandatory as we're on your way through...
DougM
