Hello,
I had my 3B enigne rebuilt at a machine shop. They disasembled the block and reassembled it with new sleeves and pistions. I put the rest of the engine back together.
After puting on some miles it was noticable that there was a lot of blow by. Without much expereince and reading some threads that it takes a long time to break these engins in. I just keep running and adding oil when needed. After about 3000 miles it realy became to much and I assumed something must be wrong.
I just took the head off and it looks like the pistons are realy poorly aligned with the cylinders. Maybe this is realy obvious but I just want to get some confirmation that there isn't something normal about a gap between the piston and cylinder when it is at the bottom of the stroke. When they come to tdc the gap is much better but I can still see it in not a uniform gap around the piston.
If the photos don't show it well I can make out the top ring the gap is large enough.
Thank you
Dan
BJ42 1982 3B with Turbo
Thank you
Dan
