Builds Rebuild of Trusty (1 Viewer)
Went out and replaced the rear lock on the ambulance donor and found the threads were wiped on the door handle and had to pry out on the plate to put pressure on the nut. Have another one coming from CCOT and had a good price.
Removed the door regulator
Before removing the lock
Installed the new lock and had to use the old spring clip because I dropped the new one.
New lock installed
I put the DS apron on to see what kind of room I have and started looking for a place to mount the Cummins fuel filter. Then straightened the old bracket that I don't remember what it was for and prepped to mount the fuel filter on the fire wall
Apron in place
Cut a piece of flat bar and laid out bolt holes to bolt to the fire wall.
Drilled the other two holes in the firewall for M10 bolts
Bolted the flat bar to the firewall
Laid out some 2"x1/2" flat bar to bolt the fuel filter head too then cut with a chop saw
Used some C- channel to weld the flat bars together and have the stand off to get around the stiffener on the firewall and bolted the filler to the bracket.
Once the fenders are done will have inner fenders fabricated to provide clearance to drop the filter and protect for anything coming from the tires.
Took the filter and mount off to grind some more on the welds then shot with paint. While the paint dried I went to ACE and got fender washers to use on the inside of the fire wall. Then put it all back together.
Did you move your voltage regulator? (Or does that not apply on a Diesel?)
The voltage regulator is internal to the provided alternator that Cummins installed.
The package for the R2.8 included, the alternator, PS pump, and vac pump.
The new rear L door handle was delivered from CCOT and while I was on a dump run picked up a M6-1 nut and a 1/4" flat washer and a lock washer. Came back and replaced the handle. While I had it open I knocked off the powdered rust inside and shot with some paint before assembling.
After seeing the rust on the pedal levers I did some cleaning and shot with paint. Still waiting on the right pedal pedal pads from CCOT that I ordered before the L handle and are stuck in the black hole of Denver, still says delivery today. The other pads I got from Ebay were for later models and are square.
The right pedal covers showed up and installed
Made up a -6 AN hose from the outlet of the filter to the pump inlet. The fitting at the filter did not come with a olive so had to order one. The push on fitting for the pump came with one. Different venders.
The push on fitting for the pump at the other end of the hose. Will connect once the other end has the olive installed.
Took the skid plate out of the solvent and rinsed it off.
Took it back inside and rolled under the truck and lifted it up with the transmission jack to check the fit. The cross member is not the issue because the pan is mounted behind the transmission. It will have to be mounted a little farther back because the added 3" of the H55F and little if any mods will be needed on the pan. I has the right coverage for the split transfer case and the drain hole still lines up with the large hole in the pan.
I will have to shim the pan down and will use 1/2" thick flat bar that I will mount to the old bolt holes in the frame then drill and tap bolts holes in the flat bar and mount the pan to the flat bar. I also found I had broken off at least 2 of the bolts in the frame when I removed it a long time ago.
I ordered some M8-1.25 all thread to hang the pan from to check what exactly will be needed to shim the pan down before I order flat bar.
One less thing to worry about.
Fittings from Jegs showed up so when out and took the -6 AN fittings apart on the filter end and installed the olive and put back together.
Removed the protective cover off of the pump inlet.
Pushed the push fitting on at the pump. I am surprised that it is not a very tight fit hope it does not leak.
Reconnected to the filter outlet.
