I want to add a winch to the rear of my 96 fzj80 "Fatback" so that i can pull up the rear axle on steep departures.....I was thinking a small 2000lbs atv winch would be sufficient...help a brother out with a few pics and words of the dos and don'ts.... seems easy enough..weld a tab on the top of the axle and route the winch to it controls mounted inside the cable....
how would you limit the winch and have a way of knowing when your axles are tucked and make sure you don't draw out too much line when dropping the axle back out (do you need to). did a search, clearly an incorrect search if one of you come up with a link.
Thanks in advance.
Thanks in advance.
