one question: is there any benefit to adding a little length for those like me whom only are running a 2 inch OME lift and 33's?..... or should I just measure the stock and recreate that length?
anyone considering those Febest bushings should do some research on reviews posted on line. it would seem you get what you pay for.
Any safety issue with using a jack to adjust pinion with the uppers out? I need to lengthen my uppers and was going to use this method, but was cautioned that with only the shocks holding the axle in place with the UCA removed it may continue to rotate and throw the coils. Have you tried this method? I was going to measure ride height and then remove coils then jack the frame back to ride height then remove UCAs then jack pinion to correct angle then measure...I would support the pinion with a floor jack and remove the lower or upper arms depending on what direction you need to go.
Use the floor jack to get the pinion where you want it and measure center to center for the overall arm length.
Make a jig with bolts welded to a piece of scrap flat bar and then go to town. This would ensure that each arm would be the same length exactly.
...via IH8MUD app
Does anyone know if an adjustable UCA are short enough to rotate the pinion angle back to 0* on a 6” lift? Per slee’s website they sell adjustable UCA but I saw a post that the arms compressed arms are the same length as stock. This could be a bad post though. The metal tech UCA are about $100 cheaper then Slee. Does anyone have the metal tech UCA with a 6” lift and stock driveline. I am hoping to use the cheapest I can purchase.
