So, I went to swap out the rear suspension today and what should have just taken an hour or two will be continued tomorrow for day two. I had read of the potential issues with broken shock bolts, especially with the rear shock mounts, and I was prepared for that possibility. I started soaking all of the bolts with PB Blaster last week, and again yesterday, in preparation for today's install. Slee's instructions in hand, I started loosening up the shock bolts, starting on the PS. Top two bolts, not a problem. Tried to go easy on the bottom bolt, but it snapped right away. Not the end of the world, I know this is somewhat common. Break out the drill and start drilling it out, right on target.
And then things turned ugly....
I probably should have drilled it out a little bit further and then tapped it, but instead I turned to the "hardened steel" extractor set from Sears that is supposed to remedy this very issue. Yeah, that didn't really go according to plan. I snapped the extractor in the drilled out hole, and it was jammed in there good. I was hoping to knock it loose so that I could pull it out, but it was wedged in there so good that it wasn't coming out. Because the extractor was hardened steel, there was no drilling it out with what I had. After muttering many select words that I won't repeat here (and luckily no one was around, because it would have appeared that I had a severe case of Tourette's), I quickly read online that the only chance I had of drilling through this was with a carbide bit. I went back to Sears to voice my displeasure with their product and figure out a way to proceed, and they were less than helpful. They wouldn't replace the broken tool, and the "tool dept clerk" seemed to know nothing about tools. When I asked if there was anyone around that knew about tools, he said there wasn't. Dumbfounded, I had make myself walk away before my next Tourette's episode.
I tried a couple shops looking for a carbide bit, but could only find carbide dremel bits. I ended going through three of the bits, and got about 7/8 of the way removing the broken extractor. Hopefully, I will end up getting the last of the hardened steel extractor out tomorrow when I get home from work. And then I will have to see what kind of tap I can run through it and either heli-coil it or find a bolt that will match so that I can get the shock secured on the bottom mount.
And then I can proceed to the DS and do it all again. Hopefully with a little less drama.
Anyways, thanks for letting me rant. Needed to get that off my chest. Wish me luck tomorrow.
