Snapping the rear, lower shock bolts seems to be a fairly common problem in the rust belt. I had PB'd mine for 5 days prior to installing my 30mm MAF spring spacers. DS came out fine but I did snap off the PS bolt. EZ-out also snapped off
doh
so I decided to drill it out (Dremel Tungsten bit) and just weld a threaded stud in the remaining cavity. I could have tapped it but did not a have a tap that large so decided to take a different approach. YMMV.
I'm only posting this to create a searchable, possible solution to a broken rear, lower shock mount bolt to help others, not to start any arguments on right/wrong way to fix things.
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo.JPG"]
[/URL][/URL][/URL][/URL][/URL][/URL][/URL][/URL]
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo2.JPG"]
[URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"][URL="http://bengal.missouri.edu/mckenziemb/Cruiser/Shock/photo3.JPG"]
