Rear Suspension Issues - Need Help!
Musta been the 39's .Interested to hear what Poly says . Just got a set ,Wheeled em' hard this weekend pretzeled a rear shaft but they held . Runnin' 37's right now but I was thinkin' about something a little bigger.
Called Poly on Monday. Very very positive response. They'll look at the pics and make a call - just being open to discussing is big in my book, that and it was the first person I talked to - 30 second conversation. Doing the teardown tonight (seeing as how I wanted to swap in a fine spline pinion diff anyways) and will send out the pics tomorrow. Out of Country surfing next week - so I'll update ASAP. Keeping my broke arse fingers crossed!
Yeah - normally limestone is slick as all get out, but I guess with the draught we've had combined with 39 Red Labels aired down was just too much. I am absolutely drooling to get out West and try some granite - have heard that traction out there is just insane!
You got a center limit strap? If not, get one and onyl give yourself about 1" droop in the center. It will at least help.
That's interesting - I will give that a try pronto - I can see the point of what it would do - Thanks. I've always thought they were just for big high flex vehicles. That would be a cheap partial solution - thanks.
He's the Poly - sent several pics to PP - owner back on Monday so hope to get a positive response. Twisted splines, bent shaft, and shattered in a place I'd never seen a stock one go before :D. Noticed what appears to be different thicknesses on the hardened outer shell?
Out the door for Costa Rica in 2 hours - will work on this when I get back :D.
never saw a stock one break there either...must be inconsistency in the metal. Hope you get your money back. Looks bent to hell as well.
stockers wouldn't break there because they neck down right before the diff... Those are designed more like minitruck shafts...
either way I am not impressed. I was right there when it happened. He had both rear tires climbing a slight under cut. He was wheeling with control and with out abusing the throttle.
