Rear spindle thread size and tips (14 Viewers)
Baton Rouge
Long story short, I stripped the spindle threads. Don't ask, it's not important, but I'm dumb. What is important is getting this thing out of my garage. I have a replacement lock washer, lock nut and screws. What is the thread size of the spindle thread? Any tips on fixing this booger without replacing the entire axle assembly?
I see this tool. Can something like this help me? amazon rethreader I can get the nut on easily until about the 4th thread and there is an abrupt stop. TIA
@SpillmanCruiser : Been discussed, IIRC M42 x 1.5 (double check that as I forget) but the dies (kit) you linked above are too small.
Double check the thread pitch:
You could try using a metric thread restorer die:
Or a thread restorer file:
Consider this set for future fubars:
More homework (there will be a test):
Added these links for future reference:
Here's a link for an Outside (or External) Thread Repair Tool:
And a video showing how it works:
Here's another Thread Repair Tool Set that works on OD's up to 6" but the price is crazy:
And another more affordable type but the largest tool of this type/brand I've found only works up to 1-1/2" (38mm) OD.
This topic (significantly damaged spindle threads) hasn't come up much in the past, so tossing out some links for future searches:
Here's another, not that much better.
I don't have the tool, never had damaged threads as bad as the OP's.
Added the links just in case others who run into the same problem and doing a search will more likely find the tool options.
FWIW
