goodtwin
So, I figure this might open up a can of worms, but here goes:
I need to change my rear pinion seal on my 1986 HJ60. Couple factors though:
1: it IS slinging oil all up around the underside of my cruiser. This leads me to believe it also needs the upper/outer pinion bearing replaced.
2: Before you ask, I’ve read several previous posts that include the argument about crush sleeves, solid spacers, to replace or not to replace, etc. I am aware that my manufacture year has the crush sleeve and I am inclined to replace it if I also replace the upper/outer bearing.
3: Is this something that I can do with the pinion in the axle? For example: to verify preload, will it be an accurate reading on jack stands allowing the wheels to free roll?
4: Do I also need to replace the lower bearing at this point?
Please let me know your thoughts.
Thanks
Thanks
