Rear lower control arm OEM difference between 95-96
FOG TOWN->SF<-
I'm looking into buying replacement rear lower control/trailing arms for my 95. When looking at a local Toyota website for part numbers they list 2 different model numbers.
to 11/95- OEM 48720-60011
from 11/95- OEM 48720-60012
Then when you look for aftermarkets, for instance SPC lower reinforced, it will fit any 91-97.
Rear OEM Bushings 48702-60040, which will fit 95 and 96
Does anyone know if there is a difference between both OEM lower control arms?
the old ones are larger in diameter than the newer ones. no idea if they are any stronger i just know that side by side they have a larger tube.
So both are interchangeable I assume.
Thanks!
