Wanted to provide an update on the 30amp circuits used for the 3rd row power seats. I've been messing with these this past week trying to work out what i'm going to do to keep my lithium battery charged in the rear. While these are fused at 30amps, I don't think you can really pull 30 amps from them. I have a 20amp DC to DC and with it connected (and pushing 15amps into my Lithium battery, right at 200w according to the shunt) it would not work consistently. With effeciency of the DC to DC, we were probably pulling 220-ish watts from the plug. On the driver side seat connector it would blow the fuse within a minute and on the passenger side it wouldn't blow the fuse but it would cause my screen in the dash to power cycle. This power cycling was occuring with the engine idling. I haven't tried mating the two wires into a single circuit, this may be the trick to get a full 200 watts out of those wires. Although, I have to assume that voltage sag caused by the load on the under glovebox fuse panel is what was causing my screen to reset, so it's possible that splitting the load across two wires won't make a difference if I was causing too much voltage drop between the glovebox fuse panel and the main fuse panel.
All that to say, I was able to run 100 watts out of each plug with no issues. I'm trying to remember if I ever ran 100 watts out of both plugs simultaneously. I should give that a try and see if I get the same effect as running the DC to DC charger at 220w. I suspect i won't blow any fuses, but may run into the rebooting infotainment screen.
