i found wear marks on the bottom edge of the backing plate. after I filed it down a bit, the noise is almost completely gone. will the rotor eventually wear in enough to have the sound disappear entirely?Look for wear mark. We this when new rotor installed, or even just cleaning the rust form hub. Dealership turn the rotor, removing some of drums lip. I find wear mark on shield, and pound outward.
Note: Brake dust shield may be perfectly straight, still this can happen.View attachment 3605600
the cardboard seal on both the left side and the right side is wavy like in your pic - does that require fixing?I should also note. The thick cardboard oil defector seal, may have broken free. This will also may rubs on drum. It happens from, over torqueing lug bolt.View attachment 3605592View attachment 3605593
It may or may not. I pound backing plate out, away from drums' lip, just a micro MM.i found wear marks on the bottom edge of the backing plate. after I filed it down a bit, the noise is almost completely gone. will the rotor eventually wear in enough to have the sound disappear entirely?
New, the carboard oil defector seal/gasket is flat. The only way to replace, is pulling axle bearing. So best, to just wait until day bearing needs replacing.the cardboard seal on both the left side and the right side is wavy like in your pic - does that require fixing?
The oil defector shield, deflect gear oil outward away from brake pads. The only time it's needed. Is when axle seal has failed.
The lug bolts pass through the oil defector shield, seal & axle wheel hub. When lug bolts are over torqued, usually by air tools. It pulls on lug, bending oil defector shield. Which can break to carboard gasket.
Two questions - as i'm trying to do a pro job, right and proper.
1) Where exactly should the brake grease be applied? Can someone draw it for me like im 5? Would like to stick to FSM - which's indicates on both sides of the inner anti squeal shim only. But where exactly on that shim then? ('opinions' on YT etc (not that that is good source) show folks smearing it all over and everywhere including in the corners of the support plates and sliding edges of the pads. What seems to be an authoritative TCMC video on the 80 series mud forum creates more confusion for me - see snap shot below).
2) Recommendations for disc brake grease?
For reference:
View attachment 3668777View attachment 3668778
Apologies if i missed a post above or thread where this was clarified.
