YellowJacket
I did do a search...
I found one of my questions on slee's site. Looks like the factory e-locker started in 93...
(((I HAVE A REAR ELECTRIC LOCKING DIFFERENTIAL FROM A 93-97 LC)))
Also, I keep getting different answers on this question. I just got an e-locked rear diff and am trying to get a solid answer on the ring gear diameter w/o taking it apart. Is it an 8" or is it a 9.5" or what?
I got this for my 87 Runner since I just broke my current ring and pinion in Moab a few weeks back. I just heard that there is no way my stock axle housing can be modified to accept this diff. (I though it was the same as the OEM e-locker found in the 4Runners.)
I am wondering if I should still try to use this diff (since I just got 4.88 yukons ordered for it) and look for a complete rear axle minus the diff of course. I was hoping for something stronger than the common 8" ring and pinion since I am running more power than normal.
Does anyone have a pic that I can check out to see what mods would have to be done to use the rear housing? I know I would have to do brake mods (drum-disc) cut off the coil spring suspension items and weld on spring perches. what else. I should probably get both axle pic side by side...
Would I have to use the cruiser shafts. I assume they are different? More splines? Wider? Larger diameter? Etc....
