bloc
Back again with something I hope will help some people eventually.
I'll try not to make this too wordy, but there is a little background. I spent months tracking down a driveline noise and with the help of some board members and especially @CharlieS narrowed it down to a passenger side rear axle/wheel bearing.
Troubleshooting thread here: New driveline noise after lift - https://forum.ih8mud.com/threads/new-driveline-noise-after-lift.1228472/
Bearing postmortem thread and pics here: Rear axle bearing postmortem - https://forum.ih8mud.com/threads/rear-axle-bearing-postmortem.1245734/
This thread is intended as documentation of my experience changing the bearing.
This is not a particularly difficult job, but requires some specialized tools that may make it out of reach for most users. Still, it can be done at home, and depending on what you already have, you can save significant money over paying someone to do the job.
What I used:
$200 - Harbor Freight 20-ton press. the 12-ton will not get the job done, the platform is too narrow to slide the adapter tool through, and frankly I don't think it has the balls.
Any press 20-ton or close will work, but the platform is the trick. You'll need at least 4" of space between the beams of the platform to get the adapter tool through. This can be addressed with the correct hardware, but that configuration is up to you.
$160 - "Bestauto" toyota axle bearing puller tool 09521-25011-0 on Amazon. There is another version of this tool that has another adapter for pulling the ABS tone ring on a Tundra/Taco/4Runner/FJC axle shaft, but that isn't needed in our case.
$70 - OTC 1123 (or larger) bearing splitter
$Free, maybe - Various sleeves and adapters for spacing/rigging parts on the press platform. Over 20+ years of working on cars I've kept things like old bearing races and hunks of steel, this has paid off for press work. Having the above tools but not having these things to do the rigging will stop you in your tracks.
$10 - (2) 1/2x10" galvanized carriage bolts, nuts, washers. If you can find 5/8x18 all-thread for the OTC puller this is better, but the carriage bolts are much easier to find and worked for my purposes.
(I'll edit this as I build the thread and maybe find more needed stuff.
Getting into this job, I assume you have some basic mechanical skill. You'll first need to remove your rear brake caliper, bracket, disk, the parking brake shoes and hardware, and make room to do work. You will need to disconnect the rear caliper hydraulic line to get it clear of a bracket mounted on the backing plate, but you can reattach it quickly and lose minimal fluid, and make subsequent bleeding quick and painless.
Here is where I'm assuming you'll be able to get without my help. Without rust this is maybe 15 minutes of work.
You'll need to disconnect the brake hydraulic line to free it from a bracket, then reconnect. Also get the caliper out of the way, but keep it from falling and putting too much force on the line. Disconnect the ABS sensor wire harness.
You can also just see the top two of the four 17mm nuts that hold the hub and brake backing plate assembly to the axle housing.
Four large nuts removed, the hub and axle shaft slide right out. NOTE: I jacked this side of the rear axle up a few inches and supported with a jack stand. This tilted it to the other side, so I didn't need to drain the gear oil from the axle housing and save a couple of steps and some time.
More to come.
What I used:
More to come.
