I am somewhat stranded (at a rental house 8 hours away from home) and could use some real time help.
Last night I went over a small bumo and heard a terrible sound coming from my driver's side front wheel. At first I thought it was the transfer case or differential, but thanks to this excellent website I learned it was something else.
I pulled off the center cap and grease cap, and sure enough my axle retaining clip was off. Problem was that I couldn't "pull" the axle out enough to clip it back on, which made me worried the splines were stripped.
This morning I pulled off the drive flange and this is what I see. There isn't even a ridge to clip the retaining clip to. Is this normal or is this extremely stripped and worn?
So with the drive flange removed, looking into the wheel I see the following. Does this look normal or do I also need a new wheel bearing?
I am not sure if you can see it but it looks like there is "metal" around the large nut.
So at this point I think I need a new axle. My question is do I need a new drive flange and wheel bearing?
Thanks for everyone's help. I spent all night reading these forums and wouldn't have got to this point without the great information on this site.
