well our benevolent leader got it to my shop in St george . found it was missing a fan blade , leaking heater tees(brass) and the fan bracket was ready to pitch off the remaining fan assy . had to wait till 11 for the usless dealer to deliver the fan ,while i got busy and replaced the fan bracket . adam gave emotional support and ate tacos , Then the bad happened!! on the road test it made a horrible sound from the right ft wheel . put it back on the rack and found the c clip off the axle and the bearing destroyed , to the point the worst i have ever seen .the entire rh spindle/hub/axle. are now welded together (pics on Monday). 2 hrs with a air chisel and still will not budge . so out will come the plazma cutter . but the knuckle/spindle is wasted . so a order was placed for a entire assy , and a new axle shaft .. . any one out there got a whole rh side he can borrow . And on the wisdom of the crowd how did this happen . did the snap ring fall off and the axle slide back and spin in the spindle and the friction failed the bearings ? . the snap ring was off when the cap came off .
