cruiserbrett
GOLD Star
Looking for a bit of help-2 hours from home with family, without my TechStream/VCI or FSM.
2000 LX470 with a noticeable misfire, Check engine alternating between flashing and solid, as well as VSC TRAC and VSC OFF lights illuminated. Truck ran fine last night-immediately had a stumble this am when first started.
What would cause this? As in, will a misfire cause the VSC lights?
How can I flash out trouble codes? I have the jumper wire. Also, can someone list the misfire codes for each cylinder?
I also travel with a spare new coil so I can change it out once I determine which cylinder is misfiring.
Thank you for any insight!
