- Thread starter
- #21
Well I cleaned the contact points inside the cap and sprayed the oil out of and off of everything with electrical contact cleaner. Also dried it out very thoroughly with a hair dryer. Put everything back together and same issue. Driveable but still an irregular misfire/thump/stutter. Does not seem to happen when revving in nuetral unless I stab the throttle. Can coast in nuetral or drive with no problem and even maintain steady speed on flat ground. Come an incline or need to accelerate and it's there again.
So for now I guess I need to replace the cap, rotor and plug wires. Also need to check and isolate the wiring harness. Just haven't had time to dig to deep into that yet.
At this point I have done the following:
-Replaced the ignition coil
-Changed the spark plugs (all gapped to .031")
-rechecked the plugs (all look good, slightly white on top of electrode but clean inside the gap)
-Pulled apart and soldered back the MAF/VAF
-changed the o2 sensors
-checked the intake hose (no cracks)
-checked all the fuses and relays that I can think of (all good)
-cleaned the distributor internals
Am I missing anything? I'm thinking if the dizzy cap, rotor, and plug wires don't fix this I'm gonna have to go to a mechanic. At a certain point I'm not saving money any more and have a tendancy to get in over my head.
