Radiator time @ 140k
Orange County, CA
Website
www.themirrorpool.com
Alright, I’m due to replace the radiator. Along with the water pump, what else should be addressed?
Couldn’t turn up the correct post for parts, if anyone has it please share.
Thanks!
Serp belt and related idlers and tensioners at least
I'd also like to confirm the new updated Toyota radiator P/N.. It seems like some of the toyota parts websites are showing it as an unavailable part.?
I need to get one to have on standby
Some websites won’t ship radiators, hence unavailable
Should head gaskets be done at the same time then? Or leave them alone…
RyanCA is the current head gasket court jester and is just ****ing with you.
You don’t need to replace the head gasket.
But you’ll want to replace your coolant every couple of years to avoid problems. Searching the forum will give you more detail. Look up car care nut or RyanCA😜😜
Didn't the water pump come with a gasket? I see that p/n showing the gasket with the pump.
I think it does come with a gasket but I can’t remember for certain.
Main water pump and thermostat outlet gasket should be in the kit.
Where did you order your parts from?
I generally use fred anderson toyota:
Another popular one is serra toyota:
Genuine Toyota Parts and Accessories: Official Online Store Serra Toyota - https://autoparts.serratoyota.com/
